Unusual belt light issue.
3.1K views 4 replies 2 participants last post by  NMKAWIERIDER
#1 ·
I have a 2009 Brute Force 750i with 2,150 miles. Here’s the issue. It’s perfectly fine for 10-15 minutes then no rhyme or reason, a solid red belt light comes on and it instantly turns off. There’s no limp mode or anything, just instantly turns off. Then I turn the key off, let the bike cool down for a few hours and it will run perfectly fine again for 10-15 minutes with no belt light. I’ve tried resetting the belt light and I replaced the belt with a new Kawasaki one. Any ideas?
#2 ·
The belt error happens when the switch breaks contact even for a split second. The ECM will hold this code and cause it to be in limp mode until the problem is fixed and the reset procedure is conducted. The fact that the light comes on without limp mode enacted and turns off by itself says it is not coming from the belt switch or an error code in the ECU. So...the belt light circuit is getting power from another source...and it seems heat-related. It can be in the pods circuit board or anywhere in the harness back to the ECU. Grab the service manual and the wiring diagram and start tracing from the pod back. If nothing I would assume its the circuit board problem...or...its may be something with the ECU or it's connectors. Pull them too...look very close are all the pins. Might have water in there or somewhere it shouldn't be.
