won’t start
248 Views 2 Replies 3 Participants Last post by  NMKAWIERIDER
When you press the starter button the starter solenoid clicks but engine doesn’t crank. Battery is fine. Replaced starter solenoid but still just clicks. Any ideas?
Really could only be two things that I can think of - weak battery or bad connection. Check the wiring carefully and look for damage. You said the battery was fine, but I’d try jumping it off another machine just to be sure.
Low power, bad cable connection, corroded connector, seized engine, bad starter motor.. Usually the battery can't deliver the required CCAs so have it load tested.
