G'day Guys
Im chasing a pdf wiring diagram for a 2013 KVF 750 and a 2014 KVF 650 i have two bikes that im using to build a good one and need the diagrams to cross reference properly. any help is appreciated.
G'day Guys
You have a real problem because 2013 was the last year of the 650 not 2014. And even if it was a 2013 650i, it will have the same wiring diagram as the 2005-2007 750s as they were carbed and never changed over the years where starting in 2008 the 750 went to EFI and then in 2012 went to a completely new system...and again in 2015. You can use a 650 in the EFI system but you will have not only adapt the TB system but change the stator and the pulse coil to the EFI's. Of course you can go the other way but the same is true on electrical and adaptions but the 750 will be camed for EFI not carbs so..its a toughie.
Anyway there the wiring diagram for the older carbed 750 which should be the same as the 650. For the 2013 750, you will need the service manual and we may still have it in Brute Technical Articles.
G'day mate
Here in Australia they still had a kvf 650 for the 2014 all im after is the wiring diagram to Compare the two as one has the 3 button display and the other has the 2 button display and want to confirm the wiring so i can modify to use one on the other. where can i find the brute technical articles on the forum??
