My son has a 2017 Brute 300. The lug pattern on the front is 4/144 and 4/110 on rear. He wants to put 12x7 wheels on it. The rear pattern no problem but the front is turning out to be what seems impossible. What are my options? A converter and go 144 to 110 to match back?
Are you sure they are different? Have you tried to put a rear wheel on the front? It's so unheard of to have different patterns like that....but then the 300 isn't really a Kawasaki, its made in Korea (I think) for Kawasaki but you would think it would be to their specs. Otherwise, yes, a set of spacer adapters to convert the fronts to 4/110 and a set to keep the rear the same with the same spacing would be the only option.
I was shocked myself but yes visibly different which was what got me measuring and then confirmed online they were different as well bc I started thinking maybe someone had altered it before I purchased. Thank you for the response I will start looking for the converter.
