Still waiting on a few upgrades for my 19 Brute to come in, slowly they are arriving. So in the meantime I do what I can, got the plastic's back on with our warmer weather here. Installed the Voyager GPS unit but didn't bother with the gps wheel sensor, everything is working perfect, water temp readout/tach/mapping. Changed my mounting a little so I could access the mini-sdhc card easier.
Mounted the winch switch at the left handlebar controls, mounted the winch solenoid on the underside of the battery box. Cleaned up the accessory wiring under the front plastic's and along the right side of the upper frame body section to the battery.
Direction2 Overfenders should be in next week along with the Aluminum Products a/arm guards. Still debating on the belly plate brand. Believe I can make my own underside footwell guards from grated metal.
Working on the Raptor look front amber but mine are
Green lights, with the Brutes upper grill having a slant to it, I have to add spacers to the lights for the correct angle of the lights, they will tie into the horn wires that are located at the top and behind the radiator, work only with Key On.
The Swaybar Bushings though wasn't as easy as the other Brutes I have had the years before 2012, don't know what changed but for the 19 Brute the Energy Suspension greaseable swaybar bushings needed modding to mount but they are installed.
Switched out the Sedona Ripsaw 25" tires over to the 26" ITP Teracross, stayed with the 12" wheels so I could stay with the Stock Kawasaki Mag looking wheels.
Installed the 1" wheel Spacers from Highlifter for a little extra width and to give a little bit more clearance on the right side at the gas tank to the rear tire.
Need to find the correct hole saw to mount a dual round USB plug at the gear shift knob.
Moved the Toolkit holder from under the seat to the left fender storage box, I drilled out the rivets under the seat, redid the rivet's at the storage box, I'll be keeping tire repair, extra spark plug's and other smaller tools in the left fender box.
