05 750i with 9 hours and 50 miles(barn find). Prev owner stopped riding due to electrical issue. Did a tuneup and found there to be a spark issue. The bike will spark once on each cylinder on the first rotation only. Tested everything and replaced crank sensor since it was out if spec. Installed new crank sensor and still same issue. Tried actuator and cdi from another 05 that is known good and same issue. It sparks once on first rotation then nothing. Tip sensor is good(according to tests in manual), wiring seems all ok other then 1 roached wire(traced back no issues). Neutral switch is good brake switch is good couldn't find any shorts. Only thing not yet replaced are the coils. When I bought the bike the ignition harness was cut and all 3 wires were wrapped together. Read on mimb that that could have friend something? But what? Any ideas are helpful.
