Does anyone know the part number of the screws that go in the recessed holes in the rear of the headlight assembly on a’12 Brute Force to connect to the mounting pillar things on the front fender? Can’t seem to make heads or tails of which item this is from the parts diagrams...
Must be looking are different parts mounting hardware. I was looking are headlight mounting stuff.
Yeah, there's an indent/tunnel on the back of the headlight assembly (outside) with a screw hole that connects to a mounting pillar on the corner of the fender to tie together the headlight and the fender. Once I took the cover plate off of the headlight assembly it was super easy to see what I was doing and get a tapping screw in there. Headlamp assembly is nice and tight now. Took all of 5 minutes. Thanks!
