1 - 20 of 24 Posts
I got my hands on a set of Rox Risers and Universal Solex handlebar with the pod dash panel. I have to say Rox products are top notch quality. The installation was pretty straight forward and simple just a little time consuming in being that Kawie has plenty of bolts to remove. Total time was about 30-45 minutes but I took my time. The only problem I had which really isn't is that the dash panel needs the rubber spacers from the stock pod and doesn't tell you so, it just takes you a few minutes to look it over and see that you need them and you swap them. You will see what I mean by my pic. The ability to be able to adjust your seating position is a great advantage especially on long rides. The wider handlebar makes steering much easier, you will see this as soon as you drive on a hard surface. I went for ride with the family this weekend and I had to drive much slower and the better seating position and wider bars really were much more comfortable and easier on the upper body. This is a great addition to your quad, total cost is under $200.
[attachment=1766:DSCF0620.JPG][attachment=1767:DSCF0621.JPG]
[attachment=1768:DSCF0622.JPG]
Before
[attachment=1764:DSCF0617.JPG][attachment=1765:DSCF0618.JPG]
After
[attachment=1762:DSCF0625.JPG][attachment=1763:DSCF0626.JPG]
Nice review! I contacted Ryan, at Rox, and they believe that the dash mount will work for Prairie's as well! I may well give the risers a try with a set of Fast Flexx bars. $$ will decide, but I am more sold, than ever, after reading your review.
Does the dash hit anything when you trun the bars? It looks like it is kind of low. I have a set of flexx bars, an realy want to mount them on my 650I.
mine doesn't hit anything there isn't going to be any movement except side to side looks and works pretty slick
can i see more pics of that bar pad? i would like to get one.....the one that comes with the solex bars is ugly
Discussion Starter #14
looks great python
I ran into a slight problem with the K&N airfilter. The filter is a touch taller then stock and it makes it difficult to remove. There doesn't seem to be an issue with the TwinAir I have. So I used 3 washers to raise my dash panal up a notch and that worked great. I am going to contact Ryan at Rox to let him know.More then likely this isn't a known issue.
With my dash panel I had to bend it up about 10 degrees or so to clear the EHS lid no biggie. When I was in my backyard giving at thrashing, I discovered that I needed to put some more ass behind the bolts holding on the risers. Nothing says exciting like letteing the bike down form a wheelie and the bars keep on going, got my attention real quick.
<div class='quotetop'></div>
i just orderd this set up. what did you guys put on for new hand grips?[/b][/b]
I installed this setup last week and then spent a week in Errol NH trying it out. wow what a great ride. put this on you ride you wont be disapointed. cheap money and only took about 1/2 an hour to install.
1 - 20 of 24 Posts
