1 - 20 of 33 Posts
http://s483.photobucket.com/albums/rr196/BFFreak_2008/2010%20ATV%20Outlaw%20Trail%20Jam/?action=view¤t=allat1_xl.jpg
Well, took it out yesterday for a little run. As expected, they do a lot better then the Bajas on the soft sand and sand hills. Climbed surprising well. Unless I purposely made it fail to climb to see where it would, they never gave me the feeling they weren't going to make it over the top. This is nice as it isn't the case with the Bajas. And they don't tend to trench-in like the XTRs or one with a deep solid bar across.
Engine Braking down hills was good although they did seem to want to slide a bit more in 2wd but nothing uncontrollable.
Trail riding was smooth and sure. They almost feel like a radial. Corners were solid with no sliding unless you wanted to, then it was easy to control and once off the throttle they snapped-back to the trail. Fun!
One thing that I expected was with the smaller amount of rubber making contact with the hard-pack, it would not grip it as well. That was untrue. My Brute with these tires wheelies easier then it ever did before, meaning it is getting better traction on the hard-pack over the Bajas. In fact, it wheelies easier on any surface with these...even easier then with the XTRs. There is something to be said for concentrating pressure in smaller areas.
Another unexpected pleasure was how easy it was to steer again with these 9" tires over the 11" Bajas on the front. I guess I have been fooling myself in thinking the Bajas didn't steer that much harder. They do. And with these Racelines, it felt like I had power steering.
Mounted on the stock rims, the overall width was approximately back to stock from 49.5" to 45.7" and of course this put some of that "Tippy" back in powerslides and off-camber situations but still way better then it was with the stock tires.
At higher speeds, say at 45+ they do have a small amount of wobble or bounce but it seemed to be coming from the rears not the fronts.
The tread pattern alternates from side to side and the rears have s depth of about 3/4" where the fronts have about 1/2". This might explain why there is no frontend wobble and why it does not tend to trench in like so many others.
I can't find anything I really didn't like about these tires. They are even pretty good in reverse up hills being a directional tire.
The only thing it needs is not to be mounted on the stock rim and installed without spacers. Yes, the rears did rub...and more then I thought it would. You will see at the end of the video. All fixed now though.
In summary, I liked them. It was a great ride and I wouldn't be worries about taking on anything. If I has a nicer set of rims with some 4+3 Offsets or some 1.5" spacers, they would stay on. They are definitely worth keeping. They do show not to be made in the USA, and they do only show to be a 2-ply tire with a 4-ply rating although they are stiff like a 4-ply. This makes them suitable for a backup set but here in the rocky mountains...and many other places around the world, 2-plys may not be suitable for the back-country. Sorry Raceline...need more plys to be trusted....or at least some time in the mountains which I intend to give them. I still like that way they perform.
Here's a little video from yesterday. Funny how the wide-angle liens always make the hills look like nothing..when they are something. Excuse my rambling at the end, those holes had me thinking and wondering why I hadn't heard or felt anything.
Anyway, you can get these tires from Discount Tire.
Raceline Tire Test Ride Video
And here are some shots with them mounted on the new wheels
http://s483.photobucket.com/albums/rr196/BFFreak_2008/Raceline%20tires/New%20Douglas%20wheels%20with%20Raceline%20tires/?albumview=slideshow
Good review. I like that straight road you have to ride on there! Reminds me of when I lived in the Midwest. Not too many places like that here in West Virginia! I still haven't hit top speed on my Brute yet, lol. I was looking in this months DWs mag and I saw these tires listed in an advertisement. Compared to the Bighorns, they are fairly inexpensive. I'd like to see how they hold up, long term. BTW-where are they manufactured? China or Taiwan I imagine...just something I always look at.
Says made in PRC. I don't know that one. I'm talking with Mike at Dick's ATV on a set of Douglas Rims for these so I can use them more often.
PRC=China...some offset wheels would definitely help.
China...well...better be a hell-of-a-deal on rims. Good thing I didn't pay anything for these tires. Douglas rims because I can get them in a 4+3 for the Brute and everyone else is either 5+2 or 2+5. The stock rear rim is about 5+2. I say "about" because its a 7.5" wide rim per the stamp and the offset to the outside is closer to 1.75" and the rest to the inside. The Douglas should give me almost 2 more inches of inside clearance.
Nice review and ride....I like the looks of the tires...How much would you have to space them out with fac rim spacing?
The backs only need another inch to miss everything. I don't believe in spacers so I am talking with Mike at Dicks ATV on some Douglas rims with a 4+3 offset. That should do it. 277.00 to my door for these. What do you think?
those are sharp looking rims should go good with the silver paint
Discussion Starter #11 (Edited)
Thanks, and the price is right...the only question is, do I realy want to spend 277 dollars on rims so I can use on a free set of 2-ply Chineese tires...thay did work damn good...by the way.
Discussion Starter #13
I wouldn't for 2ply tires, sell the tires and put those dollars aside for your future Shock upgrade.
That's probably the wisest thing to do...but man..I sure liked how they were on the sand..and man could it wheelie..almost was a rack-smacker....or box-buster!...lol :cool:
I'm just concern that if you ride up in Paliza or FR144 area's with those sharp rocks that you may tear out a sidewall, no fun with that. Of course, for the sand riding near your home, those would work out perfect.
A 9" wide tire up front has worked great for me, tried a 10" once, didn't care for the steering results.
Next time we ride together, you can check out the Seat, ELKAs, my steering stabilizer and now the terra cross tires.
Discussion Starter #15
Oh there's no way I'd take a 2 ply tire up to Jemez.
I have too. I took my brand new 05BF750 on a Trip up into the High Colorado Rockies for a 5 day ride, never had a problem with any of the stock tires and talk about Sharp Rocks, that is all there was up there.
You may be fine with these tires, at least you do have excellent grip with them.
Discussion Starter #19
So you think I should go a head and get a set of rims so I can use these. They were a lot more fun and had way more bite in sand then the Bajas and it steered so easy... If I hadn't just bought these Bajas and the 14" 112s, it would be an easier decision. I need these Bajas for the Utah rides and deep excersions..but I kinda think the 11s on the front is partly why I suddenly am having stem bearing and bushing issues as well as upper a-arm play again. Might be wise to go back to 9s again.
After thinking about it and the abuse I have given my Stock Brute tires over the years, and your Tires were Free, Heck yea, get the wheels.
1 - 20 of 33 Posts
