Hi, I need a little help I’m having an issue where my fan relay is bad. I swapped these 2 relays and the fan came on. What is this other relay for?
thanks
Two of them are the starter interlocks...that is when it's in gear you can hit any brake that causes the brake light to come on and the starter will work and the other is when the neutral light is on the starter works. If that fan relay was bad and you switched it with one of these, one of these functions now will not work.
