I have a 2010 750 brute force that is getting alot of oil in the air box none in the exhaust. Does backfire after letter off throttle from higher rpm. What would cause this do I need a new air filter because my one I have on it is creating to much suction?
All Brutes tend to do this but...only under certain conditions. First, in normal operations they will do this when climbing steep hills at higher RPMs or during long wheelies. Otherwise they will do this if: the air filter is causing restriction, the blow-by level is high because of warn or broken rings or being way overfilled on oil.
