My piece of crap works fair in forward. If I put it into reverse and there is any resistance whatsoever, it backfires like a machine gun....really. Any ideas??....Thank you
There is a reverse limiter so how does it run with the override button pressed? If no difference look to a grounding or coil power supply issue.
I appreciate your response. I will check out the things that you suggested. Thanks again for pointing me in a new direction
The machine is designed to only go very slow in revers... I am not sure what RPM is allowed in reverse but it is just enough to engage the belt. It is designed that way so you dont hurt yourself by accidentally flooring it in reverse.
