no lights or cranking
204 Views 11 Replies 2 Participants Last post by  NMKAWIERIDER
It was fine when i shut it off. a week later no cranking or head lights. The dash lights up and the brake lights are fine.....HELP!
1 - 12 of 12 Posts
Make sure the battery is fully charged and the kill switch is in the run position. Then check the fuse box and the connections underneath. Then test the vehicle down sensor.
i have the correct voltage to the sensor....can the sensor keep the lights from working?
What sensor? What year and size Brute is this?
the vehical down sensor
2008 brute 650
2008 brute 650
The vehicle down sensor won't stop the lights from coming on. Only starter and ignition. Look elsewhere like fuse box back connection, main fuse, or a battery problem.
nope....all of that is good??
does the igniter or dash panel have anything to do with lights and starting?
The igniter or CDI does. The fact that the lights don't work says there may well be a system power problem which includes the CDI and everything else related to running. Start at the main fuse and work in.
Thanks...I'll do that...maybe a ground issue?
Maybe..
Found the problem....the yellow and black ground wire that goes from the battery into the main wiring harness was corroded! just a small connection about 5 inches from the main ground wire at the battery
Crazy because the brake lights worked and the dash lit up???
Just no headlight, cranking or ignition.....
FINNALLY!!!!!!!
Thanks for your help.
Good...congrats! :)
1 - 12 of 12 Posts
