1 - 11 of 11 Posts
Good Vid, mine are so-so, too much White-out effect, guess I need to find a different location for the Contour Cam.
As I recall, the Contour doesn't have a spot meter that can be turned on or off. When inside a cab in the shade I have to have my GP's spot meter turned on to gauge the light it gets in the center of the lens which is pointed outside, otherwise it gets washed-out or over exposed. Same for when it's mounted on an outside mount..it would be under exposed if I leave it turned on. PITA :)
For yours we just need to put a mount on the rail outside.
Why doesn't the quick reply work?
I just changed the Auto White Balance to "Shade", also has "Heavy overcast", I'll be sure to bring along my Laptop so I can check and see if it makes a difference.
I'll see if I can find a way to mount it on the outside of the rollcage if that is what it takes, really don't want to buy another helmet cam till this contour stops working.
So quick reply doesn't work and No more Avatar's?
ok, I see you have to allow all content to see the avatar.
So NMK, the arrow shows the Vid isn't available:frown2:
1 - 11 of 11 Posts
