1 - 8 of 8 Posts
· Registered
So been gone for a wile but..... this brute I'd like to strangle. So I believe solenoid shorted and fried fuel pump somehow without blowing fuse. Replaced solenoid but fuel pump had constant draw. Just finished assembling new fuel pump and am about to reinstall. I know it needs 43lbs psi but I dont know the volume of fuel its suppose to push. Any help would be appreciated. Dont roast me about my laziness lol
Motor vehicle Hood Automotive tire Automotive lighting Automotive exterior
· Administrator
Nvm, how is it you fry a fuel pump and obtain a knock idk if its valve knock or piston knock irregardless I'm tired of these Chinese knockoffs ATV's
A Kawasaki KVF750 isn't a Chinese ATV. Pure Japanese...unlike the 300 which is Taiwanese. And the fuel pump problem can't produce a mechanical knock unless it let something get by to the injectors that caused some leaning...which makes some per-ditnation knock. Not sure how a starter solenoid problem can effect the fuel pump either. I wouldn't worry about volume right now..just make sure it's making the correct pressure..no less. I have a manual if you need one.
· Registered
Discussion Starter · #7 ·
I was making fun of kawasaki I know there not Chinese knock offs but in my current opinion there the same. I'm just agitated. Idk how I got knock from solenoid popping, and fuel pump getting a constant draw I think fuel pump is 53 psi it's a quantum fuel pump like what I had in before. I know oem is 48 psi but I figured with my 5/16fuel hose(previous owner light on fire burned up fuel line) since it was a little wider pressure would even out.
· Administrator
A lot of people talk about how important it is to have the correct pressure at the injector..mostly they say the pulse-width is only slightly variable with close loop systems and lower pressure causes it to get less fuel...but wouldn't having too much pressure make it get too much? On pre-2015 BFs they are not closed-looped systems so the mapping is what it gets so..it really should...IMO. :)
1 - 8 of 8 Posts
