Hi, my 08 750’s headlights are stuck on all the time. Whenever I apply brakes the headlights will get brighter! This happens regardless of switch positions: off, low, high beams. Also my rear brake light only works with front brake no illumination for rear brakes. Any advice on which connections to check? Thanks in advance
Mice...or a bad common. Inspect the complete harness...and check for corrosion on all connectors especially the one under the fuse box. You may also have a bad switch or inter-lock relay in addition.
