would like to know the best place to tap into for power for kimpex grip heaters and thumb warmer...anyone running these, best way to wire it in, relay needed or not, want to run both to one switch, which i picked up a 6 lug switch w/weather cap.
ok, look into the brute behind the radiatior (fan side) and you should see a couple of wires just hanging from the cross member that connects the upper shock mounts. one of these is brown (switched hot) and the other should be black with yellow stripe (ground). these are fused and will easily power the hot grips without a relay.
these wires are for the European horn kit and not used here, and they are close for you. i used these for my hot grips.
monty
