There are many times I'll be in the woods and have to make a tight turn and most people just back up and reposition themselves to make the turn. This is especially frequent with IRS machines.
Here is what I do...
I'll stand up and lean forward a good abount getting my weight off the rear end...at the same time I'll be grabbing my front break and applying throttle to bring the rear end around.
This technique sometimes takes a little body english but is relatively easy to master. You should be able to almost "walk" it right around a tree with some practice.
Once you've mastered this low speed feat...the same concept can be used at higher speeds when needed.
I hope this helps!
I hope this helps!
