1 - 16 of 16 Posts
So my Brute Force 750 caught fire I've been working on it for a while went through it order the parts I needed and today was the first day I got it running set the carbs to spec but I'm getting a pop through both carburetors any advice
Without the airbox on and the lid on it will run too lean and will pop-back through the carbs. Otherwise check the carb boots for splits..usually at or under the head-side clamps. Low float levels will also make it run lean.
  1. I bought a carburetor kit for it read the carbs brand new boots brand new air box air box lid filter
I'm starting to think the problem is is the original Fuel in it from when it caught fire in November
Bad fuel can do it. Low fuel pressyre/supply can do it. Too tight of intake valves or burned valve seats can do it. Low voltage can also do it. Once fixed yes, I would do the dynatek. But keep in mind it adds 5 degrees of advance so you will have to probably go to #40 pilots and maybe .040 shims under the needles.
Discussion Starter #8
So after getting the bike somewhat put back together took it for a test drive seems a lot more responsive than it did before runs pretty decent but I still get a slight pop every so often to the carbs
Discussion Starter #10
Update on the Brute Force I got the bike all running right TuneIn put about 20 hours on it and blew the motor up now I find a rebuild kit for it
Discussion Starter #13
I'm not sure exactly what happened the motor made a noise as I was coming out of a mud hole and then locked up
So it either jumped time and hit a valve or had a rod problem. Either way...very expensive. Talk with nFLOW about a rebuilt engine or rebuilding yours. Fair prices, top-drawer work and a great warranty.
I just want to say that its great that you are this dedicated. Most people would have gotten rid of it after the fire. Good luck and keep posting updates.
1 - 16 of 16 Posts
