i have a 14 brute 750 eps model but the eps does not work and i replaced the computer part and that wasn’t it so what else can it be maybe a plug someone said a plug by the belt box but i have no idea where it is
Check the motor power supply fuse, then the electrical connections at the main unit itself. Otherwise there were some problems with the earlier P/S units having issues with the torque sensor. These are fixable however it needs to be by a certified shop as parts are not available on the common market. Of course if it is determined that the main unit is the problem one can always just replace it. Not cheap though...over $1,525.00. :(
