Might be a dumb question but here we go. I have a 2005 carbed 750. The motor is toast but I found a good deal on an efi engine from 2008. Can the efi engine run on my carbs? If so do any other parts need swapped?
It can. But you will have to also switch-out the stator, rotor and pulse coil. Pay strict attention to the torque values. Very important. While there you can put the pull-start parts off the 05 engine on the 08's as well. You will also have to ensure the vacuum port is open for the line to the pulse-type fuel pump. I think in 08 they just capped it off.
