What should the compression on a 650 be?
Around 60psi I believe
the service manual specs are between 42 and 60 psi
what is the proper procedure for checking compression.
Pull start --- how many pulls
electric start how many revolutions.
thanks
thanks
Be sure and hold the throttle wide open and crank it with the starter.Continue cranking it until the gauge stop's climbing (usually only take's about 3-4 revolution's). This will give you the most accurate reading.
