Hello I've a 2011 kvf 750 eps which I'm having issues with .it will more often then not cut out and when I go to restart it it just clicks. If I give it a booster power it will restart but not under its own power .just clicks I've replaced battery twice I'm at a loss with this .any help be much appreciated
Have you checked the charging system? What is the output of the stator? How about all the battery connections and starter solinoid? And as 2011s didn't come with power steering (you state eps) it must be a SATV add-on. From experience I can tell you they pull 16-22 amps on average depending on the need. That is way more then the stock stator can put out and it will kill the standard battery in short order. I bolsterd mine with a Shorai battery and RMstator regulator/rectifier. Still could have used a 450-500 watt stator.
