1 - 9 of 9 Posts
Pulled my front axle on drivers side. And there is no round snap ring on the end that slides in diff. I can't seem to find out where to get just the ring?
Called my local dealer said the only way is to buy a boot kit for 80 bucks.
Any ideas? Anyone know the size?
8042
Thanks. I may have to.
Gona try a local place today? Maybe I'll get lucky.
This is an elusive little clip
That's the million dollar question. I Don't know.
But i will find out. I'm pulling the Diff anyway that's why i was pulling the axles. Curios myself
Yep. It could cause some damage for sure...
Hay maybe that caused the reason why im pulling it? 💩
I kinda hope they just took it off though
Discussion Starter #8
They can be bought! Gorilla axle has variety packs for different makes and models. Put whatever your ride is an they give you a couple different ones in case you have problems with axles popping out. Even some orings to put under the rings.Think i may have found an original source also. But i think you have to order a certain amount
8044
1 - 9 of 9 Posts
