I have a 2009 Kawasaki brute force 750 4x4i. I recently had to reset the belt and so I did. Now that I've done that it wont start up. Prior to me changing the belt it would start up fine. Now an FI thing is blinking on the dash. Any ideas?
Sent from my SM-N960U1 using Tapatalk
That "FI Thing" is telling you there is an error code and if it won't start, it must be more then just a sensor so check the connections,the kill switch, and that the reset short cap is not still plugged in. Also check that the fuel pump is running.
Mf FI code is reading 12. I looked up the code and it tells me it's the inlet pressure sensor, but I cant seem to find it
