Hello guys , i am new here hopping can get some help ! I have a 208 Brute Force 750 and looks like it goes in to a limp mode but wires are messed up and i cant reset the belt light . Please give me some advice how can i reset it
Thanks in advance
Need to make sure the switch is set to ON and that the switch functions correctly. Some have come apart inside and if it is tripped or has a problem...or any other reason that circuit is broken, it will never reset. So pull the cover and check..and test the switch first. If it is tripped...it did it for a reason and that's because the belt either is too loose or is coming apart so check it and the deflection. Should be between 22-27mm, no more...no less.
