Brute force 650
2K views 1 reply 2 participants last post by  NMKAWIERIDER
#1 ·
I got problem whit my brute 650 it wont go pass 60 when i tap 60 it start to bugs alot but i just rebuilded the motor and i dont know what can cause that
Do you know guys what can cause this issue plzzz
#2 ·
Usually if it isn't the RPM limiter and not the lack of power..like from a tired engine..it will be from the lack of..or too much of something...like fuel or air. Or lack of power to the ignition system. Test and check the power system, fuel supply as in fuel pressure and volume and tank vent check valve. Check the CV slides and diaphragms, check for leaks on all carb boots and air box lid.
