21 - 23 of 23 Posts
Discussion Starter · #21 ·
They look a lot alike but if it came off the belt/clutch cover, its the engine brake actuator and will cycle every time you shut off the key. If it came off the front differential, its the 4wd actuator and won't cycle when the key is turned off.
Yes, it must be the brake actuator because it came off the right side, top front of the belt/engine cover. I used to hear it cycle but not anymore. That’s the one I took apart and everything looked new. But if the motor is burned out, I’m out of luck and will have to get another one, won’t I?
Discussion Starter · #23 ·
Don't know until you test it.
21 - 23 of 23 Posts
