1 - 20 of 23 Posts
This Information was provided by BruteSmitty.
Actuator Control System Trouble Shooting,
When the actuator fails, the controller enters failure mode and the indicator light illuminates 2WD,4WD alternately.
1. If it alternates really fast at .5 seconds on 2wd and .5 seconds on 4wd then the problem is Selectable 2wd/4wd actuator.
2. If it alternates from 2wd/4wd at 1 second intervals, the problem is the Engine Brake Actuator.
3. If it alternates from 2wd/4wd at 2 second intervals, the problem is both the selectable 2wd/4wd actuator and Engine brake actuator.
Is there a way to reset or determine which one it is, mine is flashing really fast .
There is no reset. You will have to count the seconds each is on and go by the chart to see which one has a problem. I think you said the when you turn off the key you hear nothing from the break actuator, so there is a problem with it or the linkage.
So the actuator on top of the belt cover is what controls 2wd & 4wd and the brake? What bout the actuator in front case? By the way you have been alot of help.
The actuator on the belt case is only the engine brake. The other...on the front diff is the 4wd in & out.
Discussion Starter · #7 ·
It alternates in 1 second intervals, replace the actuator on the belt cover ?
That's what it says. Check all the connections first. You can also pull it, take it apart and clean it up. Make sure the fork is working correctly and that when you out it back in, the pin on the rotator fits back into the slide bushing it came out of.
Sometimes though....they are just gone and have to be replaced.
I pulled the cover today cleaned the actuator & looked at the forks , on the forks there are like 2 pads made out of plastic , those had some wear on them. Notches where it had been rubbing up against something . Before I had mentioned at times when I turned the bike off the actuator would keep making a noise , that not happening at all now. Do you think a new actuator will fix or will I need actuator & those forks? Do you see any need for me to try to reset the front actuator in the diff , like I did when resetting the the belt light . Once again thanks .
Discussion Starter · #9 ·
Once the problem is correct, the flashing will quit and they both will go back to working normal.
Thanks for the info. I removed the engine brake actuator and even tho is works dis-assembled it to makes sure all is clean. My indicator blinks about .5 secs so it must be the 4WD actuator on the differential. I will again remove it later and check it better. Going to the camp today and will have to ride 4WD all the time.
I saw somewhere where a guy modified his differential actuator using a choke cable to manually switch from 2WD to 4WD. This may be what I have to do to eliminate more electronic BS on the Brute. In doing so tell me what use is the engine break anyway? Another guy posted somewhere how to eliminate the break actuator as well using a relay but I'll have to find it as well.
The engine break keeps the belt engaged while going down hill. Without it the quad will free wheel like it's in neutral when you let off the throttle. My prairie is like that. It's no big deal, you can learn to ride without the engine break but it takes a while to get used to blipping the throttle to slow down. I rode the prairie for years like that but have gotten used to e-brake on the brutes.
Discussion Starter · #12 ·
Without the engine break, the primary will kick-out and let the belt freewheel at about 7mph. With the actuator and arm holding pressure on the primary spider, it forces it to maintain contact with the belt down to about 2mph where the actuator rotates back out.
There are a lot of things that need to be working in order for the electronic 4x4 actuator to work, including but not limited to:
Actuator
CDI Box
Wire Harness
Gauge Display
Throttle assembly
This site is great, I have not posted before but I read a lot and it helped me get my bike up and running again more than once, good luck!
Mechanical 4x4 system is always an option, eBay, search for Kawasaki Brute Force Prairie Mechanical 4wd electronic actuator replacement
Mine does the 1 second 2wd 1 second 4wd. It only does this when riding over 15mph for an extended length of time in 2wd. Doesn't do it when in 4wd riding on the mountain trails. Engine brake seems to be working while going down hill but seems to kick out when it gets going pretty slow.
Thank You
Actuator
CDI Box
Wire Harness
Gauge Display
Throttle assembly
Hello! I have a 2007 Brute Force 750i quad. I am having the problem mentioned here, with the 2WD/4WD indicators flashing/alternating at one second intervals. I removed the 2WD/4WD actuator and I disassembled it. The magnets are where they should be, the gears are all perfect and the whole thing inside and out looks like it's brand new. The gears all turned the way they should. Since I had it off, I added a little gear grease and put it back on the quad. I think there may be something else preventing it from working.
It worked fine until the battery went dead, so I'm wondering if the battery dying had something to do with it. When the battery was dying, there was a high pitched whine coming from somewhere on the quad. I have a new battery installed, and since then the actuator hasn't made its normal sound and hasn't worked. When I reinstalled the actuator, I plugged it in to the harness to check if it worked before bolting it in, and it didn't. I finished installing it so I wouldn't misplace any parts.
All of the components of the quad are so tightly packed together and I don't know what to check. I think I saw someone else mention the battery when they were diagnosing the problem, but I'm not sure. I have looked for fuses to check but the only ones I can find are the main fuses running from the battery to the rest of the quad.
Can anyone help me with some easy to follow instructions on what to do now? I'd appreciate it!
Rob
Discussion Starter · #19 ·
Rob
The 2/4wd light will flash when either of the actuators have a problem (4wd or engine brake) or the system has a problem. It is more often the engine brake actuator has the problem and sense you said it was making a sound. It's likely it's motor is toast now. You can take it apart and test but NO gear grease! These are not transmissions. The gears only turn one revolution one way then the other...and the grease makes it hard for the little motors to turn them. Don't use grease. If you must use something, use a dry lube like graphite. Also this flash pattern chart from the manual may help you.
Thank you for the reply. The part I removed and checked is what is in this picture. Is this the engine brake actuator or the 4x4 selector?
Cylinder Gas Auto part Electronics accessory Titanium
I think it’s supposed to make a sound when you turn off the ignition, at least that’s what mine used to do.
1 - 20 of 23 Posts
