I bought a 2017 KVH750JHF at an auction . Whoever had it attempted to snorkel it. There was a piece of a vacuum hose for the intake, some other type hose for the cover vent, a real botched job. I also found a opened pocket knife and a pair of pliers in the wiring under the front cover. Anyway the ECM was tie wrapped to the steering post.
What I need to know is where the ECM is mounted, there is a post on one end and a hole for a bolt on the other. I know it goes in there somehow but can't seem to see where it goes. A pic of the ECM in the right place would help. I don't want to tie wrap back where it was, but the wires are short and not much place to go from where it is connected.
won't let me attach a jpeg.
Yeah you need 5 post before you can upload anything. I suggest getting the shop manual or go to cheapcycleparts.com and look up the frame electronics. It will show where all things are.
Finally found it on partzilla. The bracket that holds the ECM ESP was missing. It was under the steering section for some reason. $50 of parts will keep the $600 ESP from bouncing around!
