I know it's been covered a million times but I'm stumped.my 07 650i quit shifting 4x4, again.figured actuator but wasn't.wouodnt do anything but stay 2wheel drive and no converter noise.i cleaned up fuse box now makes a noise but won't stay in 4x4.i run power to the diff actuator and it works,changed control box ,cleaned up connections.what else could it be? Getting tired of it I know that.
Grab the shop manual. In it you will find that when one of the actuators or the system had a fault, the 2/4wd light will flash and the controle power will be cut until fixed. How that light flashes will tell you which one has the problem or if it flashed evenly, the system had a problem...like a bad connection or ground...or bad controller.
