I got a 2012 brute force 750 I just got and for some reason when you turn the key the fuel pump will prime up and fill the lines and then when you start it it will run for ab 15 secs off the fuel that primed it up and then will die from lack of fuel I’m not sure if the fuel pump is just giving it gas when the key turns on and not while it’s running or what any guesses
