Can you drop the whole bottom a-arm without fully disassembling the hub to replace the sleeve and collar. my lower a-arm on wider end has some play. would this be the sleeve and collar being worn or could it be the needle bearing and or ball joint or all 4?
Font Parallel Art Symmetry Slope
I'll be damned. I thought they got rid of all those in 2012. Yes, you can drop the lower and replace without taking the rest apart but it's just one bolt to take the lower off the knuckle...well..and the shock. Then you can take it to the bench but you don't have to if it all isn't rusted-up too bad.
