So I just acquired a 2011 Brute 750, I was told fuel pump is possibly bad. Here's what it's doing, it will idle perfect and running with very little throttle moving. When you press throttle more it just pops or completely dies, I disconnected fuel line from the throttle bodies to verify fuel delivery test, I am finding that the fuel pump isn't shutting off at all. Any help would be greatly appreciated, I own a 2012 as well but this one is set up completely different
First you need to test the actual fuel pressure. about 43psi is what it should be..+-2psi. Also look for any splits in the TB boots, air box boots, bad lid gasket...ect.
After performing fuel pressure test I'm getting a consistent 40 psi, also it runs perfect until about 1/4 throttle
