Looking for some assistance with troubleshooting a no spark condition on my 2007 KVF750 Brute Force carbureted model. Took a gamble and purchased the ATV not running with unknown history. It only has 200 miles on it and overall in very good condition. When engaging the electric start in neutral (neutral light on) and in gear with the brake lever and foot brake engaged, the result is no spark at either cylinders.
Here is what I observed about the machine:
-New battery last year (multimeter reads 12.75 volts with a full charge)
-Electric starter cranks over smoothly and quickly
-All accessories are working; headlight, taillight, dash lights (including the neutral light)
Here are the troubleshooting facts so far:
-Started with the coils, multimeter reads roughly 6v key/power on and 7v while cranking at the power lead to both coils: Voltage drop or loss somewhere
-No ground buss bar on a 2007, checked harness plugs to fuse block and CDI, both clean with dielectric grease: OK
-Tested the rollover sensor, yield is 12v/5v at harness and 0.7v connected: OK
-Tested ignition switch, 6v at grey wire from switch and 6v at CDI plug: OK
What would be the next recommended test?
