i have a new brute but i sunk it. now ive been though all the steps of cleaning out the engine. but now own throttel it pops and misses. what to do next??????
Sounds like water in the carbs. There are drain screws on the bottom of the carbs to drain them. There will be a little black hose coming from the float bowl near the screw.
baroni
<div class='quotetop'></div>
Originally posted by FroNt_PaGe
Sounds like water in the carbs.  There are drain screws on the bottom of the carbs to drain them.  There will be a little black hose coming from the float bowl near the screw.[/b]
No doubt water in carbs after you drain the bowls good if that does not cure it there is a little weep hole in the side of the cyl. head take an air blower and blow both the front and rear head out water and mud get in there and cause spark to jump.
