<div class='quotetop'></div>
Originally posted by Bigmike750
Good point BigRueb,maybe I should have specified that. There will be two wire's together with bullet connector's, one will be brown (switched ignition) and the reverse wire will be white w/ red stripe.[/b]
I know this is probably easy, but could someone give an applicable example of how this would work.
Say you have a set of backup lights from an autoparts store with a negative (black wire) and a positive (red wire). Do you just ground the black wire, and hook the red to the brown wire on the brute? What would I do with the reverse wire from the Brute (white/red stripe).
Also, can we get an exaple on the front wires. Again, say you have a set of small driving lights you would like to use.
Thanks,
JM
