I’m completely rebuilding my 07 750 from the frame up but in the process of the removing the motor, I can’t seem to get the front and rear output shafts off. And can’t seem to find an videos to really help me out, any input would be appreciated!
Both are spring loaded and just collapse to remove however the splines can be rusted making it tough. On the rear slide the rubber boot back and spray some WD or PB in the splines to help, then with something to work from either side of the engine side yoke, like a tire iron and hammer, work it back and off the engine-side output shaft splines.
The front is similar but no U-joints and the spring box is at one end.
Thank you!
