Hello everyone, this will be my first post on this forum.
I recently acquired my first Brute. A used 06 750 Brute that isn’t running/starting optimally.
Bike is Very hard to start when cold and have to pump the gas repeatedly, once running I have popping through the carbs. I’ve done some studying and went ahead and proceeded with the following-
New plugs
New fuel pump
Fuel filter
Oil change
Coolant flush
Valve adjustment … (I’ve watched/read everything on TDC and double checked myself)
During the valve adjustment I had some issues with the front cylinder intake valves. Seems the rockers will close all the way against the valve stem even when the adjusters are fully removed. I can take a screwdriver and pry the rocker up and get a loud “click sound” and the rockers will return in the upward position like needed. (Almost like it’s under spring tension) Anyways, after adjustment the quad starts better but I still have a ping and pop at idle to 1/4 throttle. Runs good when opened up. So I proceeded to pull the carbs and inspect/clean. After some research I believe this bike has a 650 carb installed.(judging by pictures) . Could this be my problem? Will a 750 work with 650 carbs? Bike only has 2300 miles and 300 hours. But seems to have had a rough life. Other than that I know no history , could somebody have put a 650 motor on this 750 frame? Or just put a 650 carb on it? with the work I’ve done so far the only other thing I can think to check besides carbs are the cdi box.
(has dynatek installed currently) thanks so much for-any
input!
New plugs
New fuel pump
Fuel filter
Oil change
Coolant flush
input!
