Normally when the actuator controller detects a problem with one of the actuators, control power is cut to the 2/4wd switch and the light is send a specific flash pattern. Sense control power is cut to the switch but no flashing light, this indicates there is a connection or harness problem...somewhere. Check the connection pins on both the CDI and controller...look for anything different then the rest. Belt light's not on...right?
Do you have any lights or codes showing up on your dash at all? It could be multiple things. If you want a one time fix for your 4wd, check out our Sure 4 manual 4WD kits. Bypass all faulty electronics associated with 4WD and never deal with replacing your actuator again! ;) (y) Kawasaki Brute Force - Prairie Products
