carb help - Kawasaki Brute Forum
post #1 of 4 Old March 21st, 2013, 09:04 PM Thread Starter
carb help
1994 bayou 400,,, engine runs good high rpm coughs real bad at idle..I disassembled carb,cleaned all ports,holes everything with berrymans chock/carb cleaner. put new kit in it now it idles alittle better but will not runat high rpm unless choke is closed.what s wrong?
thanks for any help.
texaskaw is offline
post #2 of 4 Old March 21st, 2013, 10:38 PM
Welcome. Check float level & fuel supply. Then check for vacuum leaks and check the valve lash. Might check compression while at it. Berrymans does a good job so I can't imagine anything left in any port although kinda sounds like a problem with the pilot circut.
post #3 of 4 Old March 26th, 2013, 09:06 PM Thread Starter
well I have taken car apart 5-6 times now. Spray berrymans thru all ports,holes then blow compressed air thru all. gotta be clear.I checked voltage at battery while running,put another new spark plug, made sure all air duct is tight ,intake side checked for vacume leak,
going to adjust valves next....
texaskaw is offline
post #4 of 4 Old March 31st, 2013, 11:07 AM Thread Starter
still no luck with this thing.seems to be a lot of condensation dripping from crankcase vent,about 2 table spoons full after 2 hours
texaskaw is offline
Go Back   Kawasaki Brute Forum > General Forums > Other Kawies
