08 650 rear diff sludge - Kawasaki Brute Forum
 3Likes
  • 1 Post By NMKAWIERIDER
post #1 of 8 Old January 3rd, 2020, 02:34 AM Thread Starter
Picked up an 08 BF650, rear brakes not working. Had to use a heat gun on the diff to get it to drain. Ran Marvel Mystery Oil,diesel, atf ...filled, drove around, drained, filled, drove, drained, filled multiple times until it started getting pretty clean. Then filled with tractor oil(tractor hydraulic oil). Drained, filled, drove, etc. My rear brake still sucks, but I can lock it up if I stomp on the rear brake foot pedal. Maybe the more I ride the better it will get.
Click image for larger version
Name:	kawasaki BF 08 rear diff.jpg
mooncruiser is offline
post #2 of 8 Old January 3rd, 2020, 10:46 AM
Usually what happens is either someone road it with the parking brake on or it was miss-adjusted and they road it a long period toasting the brake disks and oil into tar. Or it never got changed and it got some water in with it over time. Maybe they will get better...but more likely they need replaced real bad. At least you got them working and maybe saved the rest of the gear case.
mooncruiser likes this.
post #3 of 8 Old January 3rd, 2020, 12:59 PM Thread Starter
Thanks. I'm going to ride it for awhile and see how it goes. I'm not sure if I will have to remove the whole swing arm/ diff assembly, or can just split case so to speak, and just remove the back half and change out the discs. Not much out there on the discs replacement with the solid axle rear, but doesn't seem too difficult. I'm using the premium tractor Orielly's) oil in it right now but have the Kawi stuff coming in tomorrow, not sure if it will make any difference. I'm assuming those discs are either worn out or glazed over like glass.
post #4 of 8 Old January 3rd, 2020, 01:06 PM
Your Tractor hydraulic oil is as good as it gets..it's fine.
post #5 of 8 Old January 3rd, 2020, 01:43 PM Thread Starter
What do you think about adding some Marvel Mystery Oil or ATF to the rear diff to help clean some of the crud out. Drain it and refill- do that a couple more times and maybe it'll help clean those discs? As I mentioned in original post that what I used to get 90% of the crud out, I was just thinking of running it (MMO or ATF) in the diff for awhile-don't think it'll hurt any bearings,etc.
post #6 of 8 Old January 3rd, 2020, 04:25 PM
My biggest fear is washing trash through the bearings and what it will do to the gear faces. If it would just wash down and sit on the bottom to be flushed-out...great, but I guess it would depend on what the "sludge" is made up with. Burned fragments of brake disks and dirt left over from mud intrusion would not be well received but if it were just burned oil...well..not so bad. If it were me I might be tempted to set the back end off the ground and fill the unit through the vent tube on top with just diesel fuel. Then just slowly spin the tires back and forth washing everything slowly enough to let the heavier particles fall to the bottom. Let it sit a few hours, then drain it. Might do it twice then let it drain over night and with the plug out quickly dump some oil and diesel through the main port to wash the bottom of the case out. Then full with regular fluid and take it for a few runs.
post #7 of 8 Old January 3rd, 2020, 10:33 PM
If all else fails can find a used diff on EBay for less than $100. It’s easy to swap out but takes a little time.
2007 BF 650, HMF exhaust, Dynatek ignition, aftermarket air filter, snorkeled, High Lifter 2 lift, 29.5 Outlaw tires, EPI clutch for larger tires, HID headlights, LED light bar, aftermarket winch, Highlifter relocated radiator with adjustable temp switch and ability to manually turn on fan, external oil cooler, All Balls Racing axles all the way around, All Balls Racing tie rod upgrade, All Balls Racing ball joints and A-Arm upgrade up front.
mrvmax is online now
post #8 of 8 Old January 4th, 2020, 01:00 AM Thread Starter
Thanks, I'll give that a try
