2012 750 EFI won't run past idle - Kawasaki Brute Forum
post #1 of 4 Old November 29th, 2017, 10:31 PM Thread Starter
My 2012 750 brute force started losing power, not running past 30 mph, and on long runs would keep losing power until it would only run 10 mph. Now, it won't run past idle. I tried replacing fuel pump with an aftermarket one on ebay. At first nothing changed, so knowing nothing else to do I took it back apart and put it back together. Oddly enough, it ran up to 25-30 mph for a while but over time regressed to the same situation. Haven't checked the vent check valve but I have loosened the fuel cap while running and doesn't change anything. Pretty sure not getting fuel. Sometimes it will not start until I hear the fuel pump turn off, then it will start. Any ideas?
750rider is offline
post #2 of 4 Old November 30th, 2017, 09:18 AM
Well, first, I would confirm that the pump pressure is low or not. Also run the tests suggest in the trouble shooter in the manual cause it could also be a voltage or power issue.
post #3 of 4 Old November 30th, 2017, 11:42 PM Thread Starter
Haven't bought or downloaded a service manual yet so not sure on specs but teed a gauge into the fuel line and started it up. Ran 35 psi at idle and steadily drops to 8 psi near full throttle. Seems to start cutting out when psi gets to 12. Also seems to bleed off pretty fast when I shut it off but not sure if that's normal. I will also check voltage as you mentioned to see if there's a power problem. Mechanic at dealer was friendly about giving me specs last time my stator went out so I will visit with him.
750rider is offline
post #4 of 4 Old July 6th, 2019, 06:08 PM
Christopher Williams's Avatar
It should have 43 pds fuel pressure running
Christopher Williams is offline
