2013 Brute Force 750 Crank Case Compatibility - Kawasaki Brute Forum
post #1 of 2 Old August 13th, 2019, 07:11 AM Thread Starter
Hi all new member here, just picked up a 2013 Bf 750 with a hole in the tranny end of the engine case. Engine still runs good but I need to replace the case. Based on my research the part number is 14001-0562 and I found a good used case from a 2011 BF 650 which utilizes that same part number. My only concern in that when looking at refurbished engines, it seems the 2012-2015 engines are different then the 2011. Can anybody confirm that I would be good with a 2011 case on a 2013? Thank you very much, also what would be the minimum you would replace when rebuilding the engine when doing a case swap?
Hoopduerr is offline
post #2 of 2 Old Yesterday, 05:02 PM
Just from what I heard in the past where people are trying to put 750 top-ends on 650sm the journal ports has to be cut for the larger sleeves. Just with all the changes in thrusting and other bevel parts and seals I would stay with 2012+ cases. JMO.
