Voyage? - Kawasaki Brute Forum
post #1 of 6 Old April 28th, 2019, 03:55 PM Thread Starter
Coolwizard's Avatar
Exclamation Voyage?
What should the voltage be on 2010 brute 750 when running? I think it would be 14+. My brute is hard to start and doesnít run well itís barely showing 13 volts at idle. I think I may have a rectifier/stator issue. Any help would be appreciated
2017 Polaris Ranger XP 1000 NORTH STAR HVAC edition (Velocity Blue) 3" SATV lift, 28" STI Chicanes on MSA Beadlocks, 5000lb Viper Max winch, SATV rear Roll Bar, SATV rear Bumper, 13.25 LED front light bar, 4" LED rear light cubes, horn, In-dash garage opener.
2010 750i Brute (CAMO)
26"Big Horns on ITP 312's, Viper Max 4000lb winch, Kawi rack extentions, Voyager GPS/gauges, Rogue grips, EPI Pink primary-Almond secondary
SOLD -'08 750i Brute (TEAM GREEN)
Coolwizard is offline
post #2 of 6 Old April 28th, 2019, 04:27 PM
Originally Posted by Coolwizard View Post
What should the voltage be on 2010 brute 750 when running? I think it would be 14+. My brute is hard to start and doesn’t run well it’s barely showing 13 volts at idle. I think I may have a rectifier/stator issue. Any help would be appreciated
Yeah..above 14 volts...as much as 14.7 but mostly 14.4. Probably a winding/coil on the stator going. Lots of those been happening. You can test them.
post #3 of 6 Old April 29th, 2019, 01:21 PM Thread Starter
Coolwizard's Avatar
I think it might actually be the battery. Even though the battery is fairly new, it was a cheap battery. The bike ran perfect when I put it up for winter but seems to be a problem this spring (has not really been rode since late fall). I looked in the manual and it says I should have 12.8 volts on the battery to consider it charged. I have less than 12 and only 12.8 - 13.2 at idle. I'm gonna give the battery a good slow charge and see if that helps. Then I'll move on to testing the stator and rectifier
post #4 of 6 Old April 30th, 2019, 02:29 PM Thread Starter
Coolwizard's Avatar
I fixed the voltage issue. it had a loose +battery connection. 14.4v at idle now. it's still not running 100%. it randomly "bogs" down with limited power. I'm going to change the air filter, spark plugs, and adjust the valves but I don't think any of these things would cause a random lose of power...... i'm thinking maybe fuel pump issues. Anyone with any thoughts about it???
post #5 of 6 Old April 30th, 2019, 08:28 PM
dman66's Avatar
I'd dump some Seafoam gas additive in the fuel tank, and see if it clears up.
05 Brute 750i Stock engine/Muzzy Pro exhaust,Vision Bruiser 14" wheels, 26" Kenda Bear Claw HTR, 3" intake snorkel w/ restriction,2" CVT snorkels,automotive 10" fan,ASR a-arm bushings,sway bar removed,buss connector mod,rejetted at #40 pilots,2 3/4 out on A/F screws,stock needles shimmed .030",# 160/# 160 main jets Keihin
dman66 is offline
post #6 of 6 Old May 1st, 2019, 02:31 PM Thread Starter
Coolwizard's Avatar
Thanks! That's a good idea !
