07 650i fuel delivery question - Kawasaki Brute Forum
post #1 of 8 Old December 26th, 2018, 06:44 PM Thread Starter
Hello,
just did a top end job and now it doesn't seem to be getting fuel to the carbs? if i prime the carbs it starts right up and runs for about 3 seconds. when i take the main fuel line off the carb it's dry? when i crank the engine with the main fuel line disconnected, no fuel comes out? It ran before i tore it apart. i can't find the answer in the manual. doesn't the fuel pump operate with the starter button and pump fuel? I know there's also vacuum to consider. did i hook up a vacuum line wrong. i have a piece of tube about 18 inches left over that i haven't found where that goes yet. it's either a vent or vacuum? any suggestions to test the fuel pump is operating correctly?
thanks,
BL
2007 BF 650i; Bigger jets, EPI springs, HMF muffler, K&N Air, CDI, engine brake override, reverse 4WD override, EPS just added. 26's just added.
rlangell is offline
post #2 of 8 Old December 26th, 2018, 08:28 PM
The "i"s have the same vacuum pulse pump as the 750s. There is a vacuum line that runs from one head to the pump...and it is about 18"s long. Once hooked up and there is fuel, then you pull the actuator controler...that's the one behind to the CDI...and you will see the fuel valve. It has to be on PRI to prime the first time. Then turned to ON to run. I usually just pull the fuel line off the carb and suck fuel to the end. That primes the fuel pump without vacuum or wearing the starter out.
post #3 of 8 Old December 31st, 2018, 08:38 AM Thread Starter
Great. thanks Man. I also looked up your previous responses to guys having the same issue. it worked!
I found the hidden vac line, looked at my pre-tear down pics, and connected the vac line to the front cyl nipple. Then as suggested, sucked up the gas line to prime it, connected the other line to the rear cyl nipple and boom, started right up!
after warming it up, i took cyl compression measurements: both cylinders approx 90 - 100 psi on a fully charged battery.
That looks a little high? I had the valves rebuilt and I used 0.010 over rings ground to lower spec on lightly honed cylinders.
it runs strong with no smoke. But! while running, i removed the dipstick and it's still blowing mist out the hole?
whatdya think?
Thanks again for help!
rlangell is offline
post #4 of 8 Old December 31st, 2018, 10:38 AM
whatdya think?
Compression's OK. Most are over what they say in the book and the mist from the stick hole is also OK..very normal. Sounds like she's back.
post #5 of 8 Old August 8th, 2019, 09:34 PM Thread Starter
Dang it, she's not back..... After rebuild i only drove it around short trips to break it in and make sure everything is cool. recently, i smelled gas, and actually saw some leaking but i couldn't see where it was coming from?
Then it started to run like crap when it got hot, and backfiring too? heavy bog, no power and backfire on decel.
I also noticed that i have a line i forgot to install it's 18 1/4 inches long and 3/16 bore? i have no recollection where it goes.
Any ideas on where to start my diagnoses? i'm bummed about having to pull it apart again....
Any help appreciated!!
rlangell is offline
post #6 of 8 Old August 8th, 2019, 10:14 PM
Well, first things first. It was running so the pump was working but...strange..the only piece of rubber line about 18"s long is the vacuum line to the fuel pump....and if it was left off, it should never have run. But, check- there is only one vacuum port on I think it's the rear head on top right in the casting. And if that like was on there and just fell off, that would explain the running issues...to the most part.
After that and if it doesn't fix it test the tank vent check valve, then fuel pressure and volume. Look at the bottom of the carbs at the bowels- there you will see two ports or nipples. The one closest to the drain screw is...the drain port. The other one should have lines on them that T together and go down the left side to a large piece of round plastic. That is your overflow ports. If the float levels get too high it comes out those so it doesn't go down the engine. If the lines are off and you were on some rough trail, that may kick some gas out them. Another thing you best check is the carb boots. They all crack..and usually where you can't see them..under or at the head-side clamp.
post #7 of 8 Old August 9th, 2019, 07:50 AM Thread Starter
thanks for the advice. I'll check the carb boots. do you think the carb boots behave differently when hot? Funny, it ran great when hot after the top end job then only recently (approx. 50 miles after re-build) started to act up only when hot?
Do you think the ignition could be affected when hot? Right now it starts up and runs great, then suddenly bogs down and backfires after 10 mins of hard riding. I can't imagine dirty jets in the carbs would only affect performance when hot? The electric fan works but isn't coming on so i'm guessing the cooling system is doing it's job? The backfiring leads me to fuel or ignition? Thanks again.
rlangell is offline
post #8 of 8 Old August 9th, 2019, 09:56 AM
Just go through it..you will find it. These carbed machines are pretty basic and easy.
