Old June 27th, 2007, 04:35 PM   #1
Default 06 650i smoking when doing a wheelie
My buddy has a 06 650i that lets out a ton of smoke after like a 50-75 yard wheelie. We tried it on my 07 750 and got nothing. Does anyone else know if theirs smokes after a long distance wheelie? He asked kawasaki what it might be and they told him they all do that then when he told them mine didn't they changed their story and had no explaination. Anyone have any ideas what this might be?
P.S. Dont know if this is where this should be but looked good enough move it if it needs it.
2007 Brute 750i, Kimpex Rear Box/Seat, Twin Air Filter, 26" XTR's
750kid is offline
Old June 27th, 2007, 04:50 PM   #2
The oil is being sucked up through the crank case vent hose to bottom of your air box. Many machines will do this, but some, like mine, never do.
A dirty air filter will contribute to this as it increases the vaccuum in the area inside the filter where the vent runs to.
Take a look at this thread
http://www.brutecentral.com/forum/in...showtopic=1634
Also, check oil level to ensure there is not too much. Be certain to screw the dip stick in all the way when checking it.
Boloiii is offline
Old June 27th, 2007, 10:10 PM   #3
Is there a quick way to check to see if this works before we do it just to make sure this is what is causing the smoke? Don't wanna rip it all apart if we don't have to. It sounds kinda the same but his is just a wheelie on land no water added. We'll try anything he wasn't very happy when mine didn't smoke.
750kid is offline
Old June 27th, 2007, 10:16 PM   #4
BRUTE650's Avatar
Rip it apart??? You simply check the dipstick, thats more simple than taking the seat off.
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
BRUTE650 is offline
Old June 27th, 2007, 10:32 PM   #5
I know the oils not to full his rear seal is leaking so he has to keep adding. Its usually low.
I wasn't talking to check the oil. I was talking about running the vent pipe from the crank case.
750kid is offline
Old June 28th, 2007, 08:27 AM   #6
Is there a quick way to check to see if this works before we do it just to make sure this is what is causing the smoke? Don't wanna rip it all apart if we don't have to. It sounds kinda the same but his is just a wheelie on land no water added. We'll try anything he wasn't very happy when mine didn't smoke.[/b][/b]
I also was talking land with no water added. Here is a quick visual check. After a smoking wheely, pull the air filter assembly and look in the area under the spark arrester and in the carb inlets. You will see a bunch of oil in it and you will also see about a 1/2" hole in the back right of this area where the vent comes in. Oil in this area means this is the cause.
Boloiii is offline
Old June 28th, 2007, 11:00 AM   #7
my bike does the samething. Smoked like heck after a long wheelie..opened the airbox..full of oil
07 BF 650i
112ss
26" Mudwisers
Dynatek CDI
Swaybar Removed
mAtTy is offline
Old June 29th, 2007, 12:33 AM   #8
rtc292's Avatar
try a one way valve on the vent hose.
Whats the difference between peanut butter and Jam?
07 kfx90
07 kvf750
07 wolverine {will someone please steal this thing}
rtc292 is offline
Old July 1st, 2007, 01:28 AM   #9
BluelightSpecial's Avatar
Mine will do that on long hill climbs too. After about 6-10 passes on the hill, it quit, but the oil level is still full. Im thinkin that I overfilled just a bit.
2006 BruteForce 650i
26" Mudlite XTR's, wrapped around 12" ss112 wheels
Warn 2.5ci
Almond secondary
Auto meter temp guage
BluelightSpecial is offline
Old July 1st, 2007, 01:35 PM   #10
Once he gets it back from being serviced were gonna snorkel it and try venting that hose somewhere else
750kid is offline
Go Back   Brute Central Forums » Riding & Racing » Riding Techniques
2006 650 brute force smoking
650 brute force smokes on hills
brute force 650 smoke
brute force 650i smoking
brute force smokes during wheelie
brute force smoking
bruteforce smokes after wheelie
stop brute force from smoking in a wheelie
Smoking uphill Wildman1988 Brute Engine & Drivetrain 23 March 10th, 2009 10:08 PM
How to cure smoking belts Jv2cat Brute Engine & Drivetrain 3 November 9th, 2008 01:03 AM
I quit smoking...... shawn3806 General Discussion 6 October 2nd, 2008 12:09 PM
wheelie pic ArcticMonster Pictures & Videos 5 July 20th, 2007 07:37 PM
BELT SMOKING DVILLE BRUTE Brute Engine & Drivetrain 3 February 12th, 2007 11:04 PM
