Brute Central Forums » Riding & Racing » Riding Techniques » Don't want to wheelie off the line!!!
Old June 26th, 2007, 10:56 PM   #1
Ike
Default Don't want to wheelie off the line!!!
Anyone have any ideas besides wheelie bars? Starting line is on a hill to start and the race is up hill from there. If I shift my weight too far forward it just spins. Normal seating position or back further and crouched down it justs want to come back over on me when it hooks. Suspension is in the softest setting both front and rear. Stock tires F & R with 4 pounds of air all the way around. Dynatek and clutching - otherwise stock. Thanks.
Ike
Ike is offline
Old June 26th, 2007, 11:05 PM   #2
Try stiffening up your rear suspension. This will not allow as much weight to transfer to the rear. The downside is it will want to spin more readily.
Also you could try different primary springs.
Use a ratchet strap to pull your suspension down and squat the machine. This will lower your center of gravity and help keep the front down and produce forward bite.
Basically, do not be affraid to try different things. But, do them one at a time until you understand how each one affects your launch. Then you can try conbinations.
Boloiii is offline
Old June 27th, 2007, 10:19 PM   #3
BRUTE650's Avatar
change your suspension so that its stiff, or like boloii said, squat it down using ratchet straps, or just lean right down on it, so that your heads almost on the pod, trying to keep as much weight as low as you can.
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
BRUTE650 is offline
Old June 27th, 2007, 11:03 PM   #4
I thought a stiffer suspension made it easier to wheelie .... If the suspension is softer there will be more compression in it ... taking the force of it. Maybe I am wrong.....
~~~ 06 brute Force 650i ~~~
Warn 2.5 winch
54"Cycle country plow
Douglas Ratllesnake wheels
27" ITP mudlite XTR's
SS ATV Bumper (Line-X'd)
SS ATV Floor board guards
SS ATV 2" Lift
DynaTek CDI
Tamarack wrap around trunk
NH Brute is offline
Old June 28th, 2007, 01:57 PM   #5
I thought a stiffer suspension made it easier to wheelie .... If the suspension is softer there will be more compression in it ... taking the force of it. Maybe I am wrong.....[/b][/b]
thats what i always thought too
07 BF 650i
112ss
26" Mudwisers
Dynatek CDI
Swaybar Removed
mAtTy is offline
Old June 28th, 2007, 03:15 PM   #6
It is all about weight transfer. Softer allows the weight to transfer to rear. Think of it like a pan of water. Pull it flat and the water goes to the back. Now tip it up in the front as you pull it and even more of the water goes to the rear.
Boloiii is offline
Old September 2nd, 2007, 06:50 PM   #7
Softer rear suspension causes bigger wheelies. Softer front suspension also allows the front to lift off nicely with the weight transfer. This is why drag racers will put a solid strut in place of their shocks.
Camo is offline
Old September 20th, 2007, 10:09 PM   #8
I know this off topic but ktm265 has my vote for best avitar but bac on track I got an updated dyna and the Dalton clutch kit and the brute wheelies way to easy so hopefully this advise will help got a drag race sept29th and I will have my muzzy on as well can't wait!
Old September 21st, 2007, 11:33 PM   #9
thanks got my muzzy on today but the jetting is off will tweek it this weekend
Old September 22nd, 2007, 11:16 AM   #10
BRUTE650's Avatar
If you don't want to wheelie off take off, buy a honda
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
BRUTE650 is offline
Go Back   Brute Central Forums » Riding & Racing » Riding Techniques
fuel line help wvMOUNTAINMAN Brute Engine & Drivetrain 3 May 19th, 2008 12:15 PM
Don't want to wheelie off the line!!! Ike Riding Techniques 6 August 1st, 2007 02:20 AM
Gas Line Filters IMPORTANT ?? Tj Craig Brute Engine & Drivetrain 1 April 8th, 2007 12:43 AM
