April 9th, 2007, 12:14 AM
Low Gear vs. High Gear
Can we clear up when to ride in high vs. low.
Light mud:
Heavy mud:
Pulling someone out of the mud:
Wheelies:
Pulling:
Just cruising along at 10mph:
Just cruising along at 20mph:
Sharp curves, decreased w/rapid increases in acceleration:
etc....
April 9th, 2007, 02:43 AM
All depends on what size tires you are running. If stock I would use high at all accept Heavy mud, Pulling someone out, and Pulling or hauling a load. With bigger tires you will need to use low more often.
April 9th, 2007, 09:37 PM
Personally, I use low gear for deep sticky mud and pulling others out. Other than that if I am just mosing around on the trails I am in high gear. To me it just sounds like the motor is trying harder when its in low... ?? Just my thoughts.
07 Brute Force 650i
27" Outlaws, Rattlesnake wheels, SSATV lift,
HMF Exaust, Moose jets & Module, 1.5" Wheel spacers
April 9th, 2007, 11:47 PM
All depends on what size tires you are running. If stock I would use high at all accept Heavy mud, Pulling someone out, and Pulling or hauling a load. With bigger tires you will need to use low more often.[/b][/b]
Agreed!
April 9th, 2007, 11:54 PM
Light mud:high
Heavy mud:low
Pulling someone out of the mud:low or high depending
Wheelies:both
Pulling:low
Just cruising along at 10mph:high
Just cruising along at 20mph:high
Sharp curves, decreased w/rapid increases in acceleration:high
Thats in my opinion
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
April 10th, 2007, 04:11 AM
Light mud:high
Heavy mud:low
Wheelies:both
Pulling:low
Sharp curves, decreased w/rapid increases in acceleration:high[/b][/b]
Pretty much the same for me too.
06' 750 Brute force 25' Mud lites ITP's AP full skids Pen locked Dynojetted Autometer temp gauge
April 18th, 2007, 12:18 PM
I only use low on big hills or if I am in a bind or deep mud.....other than that I am in high
April 20th, 2007, 10:55 AM
I never really use low, just once to make sure it worked. im running stock tires and wheels but i seem to have plenty of power and torque in high.
2007 Brute Force 750 Blue
2500lb Warn Winch
Moose Module
May 29th, 2007, 11:34 PM
I use low only for pulling someone out of mud and pulling my trailer. I've found that I have more luck in deep mud with high gear.
2006 Brute Force 750: homemade reciever hitch,Copperhead VDI
homemade aluminum front storage box and rear rack extension,
Twin Air filter, 26" Kenda Excecutioners, 3000Lb. Venom winch,
sway bar removed and washers on outer tie rods, Kawi rear storage canister
2002 Yamaha 660 Grizzly(wifes) 618 acres to hunt and ride( ours)
May 30th, 2007, 12:09 PM
I agree with pretty much all of the above; I use low seldom.
But I ALWAYS use low when loading onto the trailer or truck. 4X4, too.
Ride Safely, Responsibly, Ethically, Legally.
In that order.
After that, Have Fun!
I may be SLOW, but I'm not very efficient, either!
07 brute force 750 with 29.5 outlaws, 08 brute force ride in high or low, 2007 brute force gear reduction, 750 brute pull 29.5 outlaws, almond primary red secondary, brute force 650 stays in low gear, brute force 650 vs 750?, brute force 750 gear reduction, brute force 750 low gear, brute force gear reduction, brute force ride in low or high, do i use 4 wheel low when pulling someone out, doese a 650i brute force have the power for 29.5 outlaws, high gear vs low gear, high vs low gear, low gear vs high gear, low gears vs. high gears, mud racing high or low gear, when to use low gear on 750 brute force, when to use low gear on the brute force 750
starter clutch gear/ ring gear
oldmanbrute |
Brute Engine & Drivetrain |
1 |
April 20th, 2009 11:24 PM |
Using Low gear
canadianbrute |
10 |
February 5th, 2009 11:27 PM |
gear reduction
rsb5772 |
0 |
December 8th, 2007 02:41 AM |
Trail Gear
URABLUR |
ATV Accessories |
11 |
June 22nd, 2007 09:46 AM |
German high gear sets.
VENFORCER |
General Discussion |
15 |
February 16th, 2007 01:07 PM |
