Old April 9th, 2008, 01:07 PM   #1
Default Lift kit adjustment
Last night, we installed a lift kit on 2 P700, 2004 and 2006. Both front and rear lifted 1.5 inches... Now my question is how to adjust the camber from the front lift?
Any suggestions?
moosehunter is offline
Old April 9th, 2008, 03:02 PM   #2
I added a 2" lift, highlifter heavy duty springs and 27" tires; all total I added about 4-5" of lift (depending on tire psi) and to be quite honest, I really haven't seen the need to mess with the camber. I'm not sure how high you lifted your bike, but it may not be necessary. If so though, I have read on the highlifter forums that camber can be adjusted by the addition of some washers somewhere in the suspension components. I did however have to change my toe settings. I tried toe-in, toe-out and have finally settled on a neutral toe on my '08 Brute. Hope it helps.
Waterfreak66 is offline
Old September 5th, 2008, 06:51 PM   #3
Default Re: Lift kit adjustment
You can't adjust camber or caster. Just set your toe and you're golden.
Camo is offline
Go Back   Brute Central Forums » General Forums » Other Kawies
lift kit adjustment
lift kit toe adjustment
suspension adjustment jhaynes75 Brute Tire & Wheel Combos 14 December 16th, 2009 08:34 PM
valve adjustment on a 08 badbrute750i Brute Engine & Drivetrain 0 December 10th, 2008 08:49 PM
Valve Adjustment Dtew Brute Engine & Drivetrain 1 February 19th, 2008 09:43 PM
valve adjustment bowhunterrj Brute Engine & Drivetrain 1 September 18th, 2007 10:12 AM
Gorilla Lift or Turner Lift Pros or Cons bimrancher Brute Chassis & Electrical 9 January 8th, 2007 08:22 PM
